メインコンテンツにスキップ
Released in 2011, the Asus K53SV is a 15.6-inch laptop with a 2nd-generation Intel processor and a dedicated Nvidia graphics card.
5回答 すべてを表示
Can I replace my existing K53SV motherboard with K53SM motherboard?
Hello,
I bought Asus X53SC-SX224D model on 2011 which has following specs:
- Motherboard: X53SC - K53SV REV 3.0 (PCB MADE IN CHINA)
- RAM: 2x2GB DDR3 1333
- Graphics: GT520M 1GB VRAM
- Battery: 4400mAh 4-Cell
- Processor: 2.3GHz i5 2nd Gen Processor
- DVD Writer
Now, this motherboard was damaged and I'm planning to fix it or replace it.
Can I get a new K53SM motherboard instead of K53SV? Will K53SM motherboard supports all my existing external hardware components?
Are the motherboards part number specific?
Can we use 1600mHz DDR3 RAM?
Existing K53SV: https://www.empowerlaptop.com/p/asus-x53...
New K53SM: https://www.empowerlaptop.com/p/asus-k53...
Thank you
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Hi!
You can replace your motherboard with the one you want to replace it with, they should be compatible.
As for your second question, about the RAM, you can use DDR3(/L) 1600mHz DIMMs, but they will switch automatically to 1333mHz regardless because 2nd gen Intel Core i-series chips don't support faster speeds.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
Thanks Alex.
さんによる
is the ks53m better than the ks53v?
さんによる
コメントを追加
回答を追加する
Prasanth G さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 4
過去 30 日: 18
今までの合計 1,229
