メインコンテンツにスキップ
The B6 and B7 versions of the Volkswagen Passat are front-engine large family cars produced by Volkswagen, a German automaker. The B6 line of the Passat was produced between 2005 and 2010, and the B7 line was produced between 2010 and 2015 as a facelift of the B6 line.
27回答 すべてを表示
What specifically does the yellow engine light mean?
The yellow engine light came on and my manual simply states to get it to a Volkswagen dealer. How serious is this...what are the possibilities? I live 1.5 hours from the nearest possible technician.
Update (12/03/2017)
Tysvm. I do not have a obd and cannot have one until the 11th(I'm very rural)... I'm wondering if it's safe to drive until then. I drive 80 mi a day for work.
Again, ty for that suggestion!!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
2 件のコメント:
What's your current mileage?
さんによる
As @mayer asked, what's your current mileage? At what previous mileage did you get an oil change?
さんによる
コメントを追加
1 件の回答
A lit engine light can mean many things. any chance you have an OBD-II reader?
https://www.walmart.com/ip/Fixd-72312029...
Note: my car knoledge is very limited so after this I'm not sure If I can help you.
このアンサーは役に立ちましたか?
スコア 0
8 件のコメント:
Dee, if you are in the United States, most auto parts stores will give you a read of your engine codes for free. The yellow engine light normally means oil change is due, but like @captainsnowball stated, it could mean something more dramatic.
さんによる
@avanteguarde I thought they will only give the codes in MA because it is a state law. (Source: that thing on iFixit that pops up and says: "protect your right to repair" But, probably not the most informative source on that matter.) and also, isn't an oil change needed represented by a little oil applier thing? This thing: https://content.repairpalcdn.com/images/...
さんによる
well then... It appears I am wrong. I made a good answer so I shouldn't get cocky.
さんによる
@captainsnowball we are all here to help people. No worries. It's not a contest (at least not to me).
さんによる
3件以上のコメントを表示
コメントを追加
回答を追加する
Dee Jarrard さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 2
今までの合計 256
