メインコンテンツにスキップ
様々なテレビブランドとスタイルの修理ガイドならびにサポート
9059回答 すべてを表示
Panasonic TH-L42ET60A TV has sound but no picture
TV has no picture, but has sound. When tv is turned on it has a faint light to it (appears to be LED backlight). Have taken rear panel off and connections look fine and has no blown fuses. When TV is turned on has solid green LED illumintaed. Any suggestions?
Update (12/03/2017)
Have looked at all boards and checked fuses and are ok, all connections seem fine and nothing seems to be overly hot when tv is turned on (see pictures)
Update (12/03/2017)
@oldturkey03
The fuse is intact, can you elaborate by what you mean about checking pins 1-5 on connector 1?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 3
6 件のコメント
how ken problam this solution
さんによる
Hi Team,
I have a Panasonic TV screen lights ON but, no sound and pictures
さんによる
Hi @michaeltolasi
What is the model number of the TV?
Can you see the logo/menu screens at all?
さんによる
Hello I am facing the same issue. TV is less then 1 year and the problem is coming frequent.
Suddenly picture goes off only sounds are playing. After switch of and on again it's running smoothly. Is it a problem? Or there is some special feature?
Thanks
Please help
falguni.roy1@gmail.com
さんによる
Hi,
If the TV is less than 1 year old, it should be covered by the manufacturer's warranty.
Consult the warranty statement that should be with the documentation that came with the TV (or maybe it's in the User manual) as to what to do to make a claim for a manufacturer's warranty repair or replacement.
さんによる
1以上のコメントを表示
コメントを追加
3件の回答
最も参考になった回答
@ethan1992 remove the back of your TV see and check the boards for any obvious damage. Leaking or domed caps are not uncommon. Check the fuses on the power board, as well as the fuses on the t-con board. You do want to post some pictures of all of your boards with your question. that way we can see what you see. Use this guide iFixitでの質問に画像を追加する方法 for that. AS you've mentioned "has a faint light to it" probably your backlight working but not getting a signal.
Update (12/03/2017)
@ethan1992 there should be another board under the cover on the center bottom of your TV. Let's take a look at that one. Check connector 1 on the LED board to see how much voltage you get on pin 1-5. Check the power on the fuse on the same board as well. Check either side of it and let us know.
Update (12/03/2017)
@ethan1992 I was referring to the voltage on the LED driver board connector 1 "CNT1". Measure the voltage on those pins with your set on. Make sure that you do not touch other points with your probe and measure the voltage. You can use pins 6-10 as ground. Remember this is DC voltage so set your meter accordingly. Also measure the voltage on the fuse on the LED driver board and the T-con board let us know what you get.
このアンサーは役に立ちましたか?
スコア 2
9 件のコメント:
Checked pins, 1-5 had same DC voltage 23.45V and fuses checked out fine
さんによる
@ethan1992 that sound like the right voltage for the LED driver board. Should now be a toss up between your T-con board and your mainboard. What voltage do you get on the fuse on the T-con board.
さんによる
Appears to be 0.5VDC if I’m measuring correctly (between fuse on T-Con board and ground pins on LED driver board connector 1)
さんによる
Try a different ground see what you get.
さんによる
Every other labelled ground I can find produces same result
さんによる
4件以上のコメントを表示
コメントを追加
Hi Ethan. When you turn the TV on, stand directly in front of it and try shining a flashlight directly at the surface of the LCD panel. Do you see the Panasonic logo or any source image when the TV boots up? It will be very faint. Sometimes putting the flashlight at an angle gives you a better view. If you are seeing an image, your backlight is problematic and your LCD and main driver board are working correctly. The problem can now be 1 of 3 items: The power supply, the LED power driver board (if its separate from main power supply) and the physical LED strips themselves.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Thanks Anthony, I had a look with a flashlight but was unable to see any text or logos when turning on the tv, do you have any other suggestions?
さんによる
コメントを追加
Hello, I know this is bringing back an old thread but I have the same exact problem. I have followed all the advice given, and my fuse is fine and pins 1-5 all ready 24V just like you. Did replacing the TCon board help? I'd prefer not to waste the money on it if I don't have to. Thank you!
このアンサーは役に立ちましたか?
スコア 1
3 件のコメント:
Yes, replaced the T-con board and it fixed the problem
さんによる
Thank you for the advice. How much did you pay for yours and where did you find it?
さんによる
I replaced the t-con board and still no luck. Is there anything I have to do to reset it maybe? Is there anything I should do? Or does anyone have a different suggestion on what could be wrong? Thank you.
さんによる
コメントを追加
回答を追加する
Ethan さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 2
過去 30 日: 3
今までの合計 22,424
