メインコンテンツにスキップ
This is the device page for the Samsung Galaxy J7. The OS that comes stock to the device is Android OS v5.1.
170回答 すべてを表示
How much would it cost to repair my charging port that doesnt charge all
It doesnt charge and when i put the Charger in a small piece fell out of the charging port
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
5 件のコメント:
how can I fix mine bc its not working
さんによる
I cant get mine to do anything it just wont charge , it use to go on and off
さんによる
When i plug into the port the bell sounds. But as soon as I let go; the charging signal disappears. I cant get the plug to hold onto the inside of the phone i guess?
さんによる
Hi, wanted to ask how much would it cost to fix a charging port on a Samsung device please
さんによる
Hi @ adrian ashworth
What is the model number of the device?
さんによる
コメントを追加
2件の回答
well you can take it to a local repair shop. Most shops will charge between 70-100$ CAD to replace a charge port on that model.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
what if you have rice stuck all the way in the back of the charging port how much to get that fixed for a 6s or is there a way to get that out
さんによる
O.k, you have a grain of rice stuck in your tablet's or phone's charge port. Here's what you need to do!
Get a flashlight, a stick pin, and glasses if you wear them, you don't want to touch or ruin a delicate part inside of that tiny hole. Shine the flashlight straight into the port, take the pin, "preferably a long stick pin" then go ahead and try to poke the grain, and bring it out, that simple. Or use a suction method.
GOOD LUCK!
S B
さんによる
コメントを追加
It varies, if the cost to repair the charging port is higher than the original cost of your tablet, I suggest purchasing a new one. The costs of tablets are not expensive as they used to be. Now days you can get a decent tablet for $99-$200, but that depends on the brand, style, and gigabyts, 4,8,16,32,64, and up. And always get a second, maybe even a third opinion, when it comes to getting something repaired, there are scammers out to RIP you off!
GOOD LUCK!
S B
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Maria Sánchez さん、ありがとうございました!
統計データ:
過去 24時間: 5
過去 7 日: 30
過去 30 日: 63
今までの合計 17,613
