How can I get the internet to work.
I am trying to connect to the internet on my new device. The Wi-Fi works on my product but does not recongnize the internet.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Hi Neil. There are a lot of variables at play here. Let's start from the top.
Your internet is provided by an ISP (internet service provider) like verizon, comcast, att, charter or optimum. You have a modem box that connects the outside world internet to your home. That modem box is then connected to a wireless router which routes the signal from the modem into the airspace so devices with wireless antennas and the appropriate networking hardware can connect to the internet.
First, to make sure your internet is working, here are some items to test:
If you have answered all of the questions above with "yes" then your internet most likely works, and your tablet is having trouble connecting.
On your tablet, make sure you are not in airplane mode. You will find airplane mode in quick settings. With airplane mode off, go to "wireless & networks" and select Wi-FI. Make sure the "WI-FI" option says "on." Observe any network names that show up in the wi-fi scans. Do you see a network with the name you setup? If so, connect and enter the password you setup. Entering a password for the first time in your device can be troublesome, so select the "show characters" option when typing so you can see any typing mistakes while entering the password.
If you follow these steps, your tablet should be on the internet and ready to go. Good luck!
このアンサーは役に立ちましたか?
This devise was made in 2013
It has limited capabilities.
U must reboot after wifi network is saved.
It will not play raid shadow legends.
It may type or YouTube has camera.
このアンサーは役に立ちましたか?
Same issue. Brand new .it connected before and now it just show saved
過去 24時間: 1
過去 7 日: 1
過去 30 日: 17
今までの合計 969
