メインコンテンツにスキップ
Repair guides and support for smaller headsets that rest on top of the ear, also known as supra-aural headphones.
60回答 すべてを表示
Why does my headphone keeps beeping very frequently?
I have Skullcandy Hesh 2 wireless headphones which keeps beeping in duration of every 5-7 min even when its battery is more than 50% . Please help
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 11
8 件のコメント
Please Help my bluetooth headphones left side always makes a beep sound when playing something or whenever the headphone hears a sound played on it .it is very annoying please help..it does not fix it like the low battery etc
さんによる
got the skullcandy corded headphones and it would make those "grounded-like" noise :( what doi do with it?
さんによる
My bluetooth headphones keep saying “your device is connected” and beeping nonstop. The voice is every 2-3 minutes, the beeping is every 30 seconds
さんによる
Any luck? My skull candy hesh 2 r doing the same thing sooo annoyed
さんによる
I have blue tooth candie couture headphones, and they're beeping, even though I charged them all through the night, and won't stop even after I tried reconnecting them to my phone.
さんによる
3件以上のコメントを表示
コメントを追加
13件の回答
最も参考になった回答
Pair the device again. Both the device and the headset. Skullcandy headphones make this noise not just when the battery is low, but also when it becomes connected without pairing (like starting music on a nonprimary device that it had also been paired to).
In short, redo the bluetooth connection, that should fix the beeping
このアンサーは役に立ちましたか?
スコア 7
4 件のコメント:
This seemed to do the trick. I haven’t tested them fully to see if the problem persists. The issue is unpredictable, but so far it seems to hav stopped just from forgetting the device and re-connecting
さんによる
My issue was for the ink’d wireless 2 earbud though. So it seems like it’s a problem with several skullcandy headphones.
さんによる
Thank you so much! Worked for me
さんによる
Yeah! And what causes that, to beep?
さんによる
コメントを追加
hi i also have the same problem before but thru research i learned to just holding the volume up or down to stop the beeping sounds. connect to it to your phone and then hold the volume up or down. just try it. works on me. ☺
このアンサーは役に立ちましたか?
スコア 7
12 件のコメント:
This really works! I pressed and held the volume up button and it stopped beeping!! Thanks!!
さんによる
Thanks a lot! It works on mine too.
さんによる
It's not working on mine... ☹️
さんによる
It’s not working
さんによる
Mine too it wont work
さんによる
7件以上のコメントを表示
コメントを追加
It does that to let you know your volume is too high.
このアンサーは役に立ちましたか?
スコア 2
3 件のコメント:
To fix it just turn them down and it’ll stop.
さんによる
I muted it but it did not work
さんによる
Fixed my problem. I tried everything above turned it down one click no more beeping.
さんによる
コメントを追加
I found a button pressed (i.e. stuck in and broken) and not returning due to spring failure beeps every 2 seconds. Manually pull button out.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
As far as I know beeping is only for a low battery indicator.
Sounds like you have faulty headphones.
I would contact Skullcandy on repair or replacement.
https://www.skullcandy.com/customer-serv...
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
I fixed it. For phones with Qualcomm processors switch off aptx codec mode to most stable connection mode in blutooth settings in phone.
さんによる
コメントを追加
For me during conference call, Mute/Unmute/Mute your phone, and ++volume on headset. The beeps ended there.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
It didn’t work for me appreciate the info! My Iphone Had 5 got a 11 still beeps after call if I don’t answer it tried volume didn’t work ;(
さんによる
コメントを追加
I have the same issue with Skull Candy… I suspect it’s our internal bloatware, it only seems to happen on my work machine. I think our firewall is blocking it, because after I get this it won’t connect again. Very frustrating.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
One side of the ears want slides up like it used to do.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
They are overheating give it a while
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
Feel the right part of the headphones and boom problem solved
さんによる
One of the volume buttons are stuck, pry it up without breaking and it should stop the beep.
さんによる
コメントを追加
Beeping solved on iPhone bluetooth
Simple- turn off all haptics settings when listening to music. For some reason some haptics are triggered.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
It may be , because of your settings.
My problem solved when I changed the settings.
  1. Go to settings.
  2. Then click Notifications
  3. There will be a list of apps which recently sent notifications. Found Android System among them and open it.
  4. Scroll down and look whether the option “ Apps are using mobile data “ is on.
That was my problem. After I turned it off everything became alright ?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Wash the bt circuit board with wd 40 or petrol and scrub with tooth brush gently wash it again with petrol and leave it for dry when it's dry reassemble headphones and enjoy ur own maintenance why bt headphone have beep sound because sometimes carbon can make buzzing humming sound I have done this process and it's really works
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
hii im also face this problem this website is helpful for me
there are 8 reason 1st technical issue wiring
i suggest you this website it will be helpful for you
Update (11/29/2022)
hii im also face this problem check this steps
low battery sign distance between the device and headphones technical problem in the headphone check this website
it will be helpful for your headphone im also clear this problem from this website
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Kartik Gupta さん、ありがとうございました!
統計データ:
過去 24時間: 30
過去 7 日: 142
過去 30 日: 1,053
今までの合計 144,233
