メインコンテンツにスキップ
"Unable to join WiFi network" How can I fix this?
So, my iPod Touch 1G just arrived today and for some reason, the WiFi has a weak signal and it says "Unable to connect to the network". Does anyone know how to fix this?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Unplug and plug in router. Move close to the router (try this step first). Restart iPod. If all else fail try full erase.
Update (01/13/2018)
Is the iPod used? Or new? A used iPod might need the Wifi antenna replaced or it could’ve come disconnected. Most of those are little (coax) cables but they look different in a phone or ipod/iPad. I wouldn’t suggest doing this yourself because iPods are the hardest Apple device to get into unless you like soldering. Sorry for the late reply. I hole this helps if you’re still having the problem
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Everything i tried failed, even the reset. What do I need to fix?
さんによる
コメントを追加
回答を追加する
superlions16 さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 4
今までの合計 580
