メインコンテンツにスキップ
2013年9月10日に発表されたApple iPhone 5sの修理情報とガイドです。モデル A1533、A1453、A1457、A1528、A1530、A1518。
3530回答 すべてを表示
Lost “setting, battery usage” after battery replacement. All else grea
Replaced battery. Reset phone. Discharged to zero multiple times over 2 months. Battery usage just states “battery uage will be available after a few minutes ”
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
最も参考になった回答
Hey there! iFixit employee here. I just tested several batteries in benches, and I haven't seen any issues with showing usage. If you haven't already, hold the power and home buttons to do a full reset, and see if that solves the issue. If you don't have any luck with that, you may actually have some minor logic board damage.
Hope this helps, and remember not to take everything an Apple Tech will tell you at face value. Happy repairing!
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Thanks for the info. I will try the reset again. It is good to know that the battery should work properly.
さんによる
コメントを追加
Did you remember to make sure iOS is updated to the latest version? If not, check for iOS updates. (settings>general>software update)
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
Yes, I have been sure to update IOS. Just for the security updates if nothing else. The replacement battery was branded as "ifixit" and purchased at Fry's Electronics. The Apple store tech says that there is a chip in the apple battery that is not in the aftermarket. I have no idea if this is true. It is very puzzling that everthing works except the battery use indications. That is why I posted my question here.
さんによる
hold on. I'll answer your question once I get a answer from iFixit's product inquires
さんによる
コメントを追加
回答を追加する
Mikee K さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 282
