メインコンテンツにスキップ
creates popping sounds when I turn on my tv
i heard just recently noise coming from the fan i believe, or should i say the sound produced by the fan is becoming obvious. Then just last night I heard popping sounds that caused the picture on my tv to come off. I could still open my tv but then these popping sounds still causes my tv to affect the picture. I worried that it may explode so I just turn off my tv. May I know what causes this and can I still fix it?
Thank you.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
@canoi it most likely will not explode but it may stop working. You want to go ahead and remove the back of your set and take a look around on the boards. See if you can determine where that noise is coming from and if there is any damage to any component. Post some images of your boards with your question so that we can see what you see. Use this guide iFixitでの質問に画像を追加する方法 for that.
Right now going by the noise you are describing, this could be an issues with the caps, or MOSFET's. But we would have to see more of what the boards etc. look like.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Dencio さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 3
今までの合計 1,023
