メインコンテンツにスキップ
The ZTE ZMax Pro is identified by its black color, rear fingerprint sensor and its model name, Z981, which can be found under the rear case.
133回答 すべてを表示
Will not turn on just blinks
Hi I have a problem with my zte zmax pro. It will not turn on an the screen has not ever shown an image. If I hold down the volume up and down without the power button it will show up on my pc. It will not boot into recovery or download mode. I was wondering if there was any way to flash stock software staright through my pc sense the phone will appear. Is there any way to flash stock rom without the phone being in recovery mode?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
2 件のコメント
For the record you posted this yesterday. But anyway,
さんによる
Oh it feels like a long time fsr
さんによる
コメントを追加
7件の回答
ベストアンサー
If you have this issue it means the phone isn’t sensing the battery. As mine had the battery connector unplugged presumable from a drop. I hope this helps someone as it fixed mine.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
You should never put your phone n the freezer to reserve battery life ! You have water damage to your phone that is why it is not sensing the battery . You might as well presume it dead for good. It's not worth spending money on to fix either. This information I'm giving you is from experience only . Hope it helps you out . :)
さんによる
No I said putting it in the freezer helped it show a screen. I disassembled it and found out that the battery was unplugged so I just plugged it back in. It was working fine when I made this post. Also if you leave it in the freezer for a short amount of time it shouldn't do any damage ot your device
さんによる
コメントを追加
最も参考になった回答
If you don't care for data loss, follow this Procedure:
"Master reset with hardware keys
A master reset restores the original factory settings and may delete your personal data on the internal storage, such as downloads, ringtones, images, apps, contacts, and Visual Voicemail. It does not delete data stored on the SIM card or SD card. If the device menus are frozen or unresponsive, you can master reset using hardware keys.
Back up data on the internal memory.
With the device turned off, press and hold the Volume Up and Power buttons until the ZTE logo screen appears, then release.
Press the Volume down button to highlight wipe data/factory reset.
Press the Power button to select.
Press the Volume down button repeatedly until Yes -- delete all user data is highlighted.
Wait as the device resets."
for more info go to https://support.t-mobile.com/docs/DOC-27...
このアンサーは役に立ちましたか?
スコア 2
16 件のコメント:
If this is what you wanted, make sure to hit accept answer! that will give me and you reputation!
さんによる
I already mentioned it will not boot into recovery mode. This is the first thing I tried to do.
さんによる
Oops Haha... Let me do more searching
さんによる
Im so sorry for the inconvinience
さんによる
Hmmm... Did you do anything to it before? Drops? water damage? etc?
さんによる
11件以上のコメントを表示
コメントを追加
No display? and it NEVER has shown a display? by that I'm presuming it's new and has a hardware defect. You should return it to get a free replacement.
このアンサーは役に立ちましたか?
スコア 1
4 件のコメント:
No the phone did use to work. I meant the screen has never turned on for a month. If I put it in the freezer for 5 minutes it will say dead battery but nothing else happens
さんによる
Why'd you want the battery dead?
さんによる
I also do not want to return the phone.
さんによる
I didn't want the battery to be dead. It would stay on that screen until I unplug it and then return to blinking the home button
さんによる
コメントを追加
Here, This will force your phone to reboot. http://www.hardreset.info/devices/zte/zt...
このアンサーは役に立ちましたか?
スコア 1
9 件のコメント:
If this helps make sure to mark as answer!
さんによる
Do I just tap the power button once or hold it down?
さんによる
Wait this is instructions of how to reboot a phone when its glitching. My phone wont even turn on.
さんによる
Hold I'll presume. Hold for a minute or until it reboots.
さんによる
I have. In fact for an hour. The phone wont do anything. It will be recognized by my pc if I hold down vol up and down. Is there anyway to force it into recovery mode from my pc?
さんによる
4件以上のコメントを表示
コメントを追加
Yeah. You cannot fix the problem . Its better just to dispose of it properly because it has water damage( from probably water from the freezer or dropping it in the toilet) and it's not worth spending a lot of money on it to try and repair.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
this was no help at all.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I had the same problem. Just let it charge for 10-20 min. And then turn it on and might sound crazy but plug another charging port and it should work.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Jakob Kenley さん、ありがとうございました!
統計データ:
過去 24時間: 6
過去 7 日: 23
過去 30 日: 70
今までの合計 21,065
