メインコンテンツにスキップ
Released in April 2011, the D5100 replaces the D5000 as one of Nikon's popular consumer DSLR cameras. It features a replaceable Nikon F-mount lens.
53回答 すべてを表示
Error “press shutter release button again”
Can I repair shutter release button error?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
Hello, can this fix work for Nikon d5200?
さんによる
コメントを追加
3件の回答
ベストアンサー
I just had a similar problem on my D5100 and was advised to send it back for repair. After comparing mine side by side to another at a camera shop, (remove lens and with camera on press shutter release button) the lower right corner of the mirror was binding with the stop. We were able to GENTLY pry the lower right corner of the mirror away from the stop (from the right, not underneath) and now it is functioning flawlessly.
このアンサーは役に立ちましたか?
スコア 7
9 件のコメント:
THANK YOU SOOOO MUCH!!! That was the problem. Works perfectly again
さんによる
Wow such an easy fix I had just put the camera on a shelf for 2 years found this and I have the camera back! Thank you so much I am sooo happy!
さんによる
Thank you very much your answer. You saved my lots of times. Thanks again buddy.
さんによる
You're a lifesaver, thank you very much. I was seeing big $$$ signs to get it fixed. Such an easy fix if you are very careful
さんによる
you are savior.. after 2 years I already got the answer.. Thanks to google too..
さんによる
4件以上のコメントを表示
コメントを追加
What if it’s doing the similar to myD5200 and it’s not the corner of the mirror sticking?
このアンサーは役に立ちましたか?
スコア 0
3 件のコメント:
I had the same error message on my nikon d5600 and I have managed to fix it by using an external flash > I've simply attached an external flash to the body, turned the camera and the flash on and suddenly everything was working again. I shot some pictures and removed the flash. The error message disappeared and the shutter release button works again as well. I hope this helps for you :)
さんによる
Mine is d5200 having the same type of problem but in my case the mirror isn't moving only the left side lever is moving. Any solution please
さんによる
@remo1098 I have the same issue... there is a slight clicking sound but the mirror is not moving only the left lever... found any solution?
さんによる
コメントを追加
Error press shutter release button again
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Jack さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 10
過去 30 日: 68
今までの合計 18,357
