メインコンテンツにスキップ
Samsung Galaxy Note 5は2015年8月に発売されたSamsung製のスタイラスペン付きファブレットスタイルのスマートフォンです。
271回答 すべてを表示
Why does my phone vibrate when it turns on after it was off?
So after I restart my phone, it vibrates when turns on, or when I turn it off (completely) and then on .
I don't know why it happens but I can give you more details if you ask me to.
It might be because of a specific application and because no one asked that so it might be because of oculus vr.
Why is it a problem?
Well after it happens my phone becomes slow for a short amount of time and then coming back to normal.
Please help!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
3件の回答
最も参考になった回答
Most Androids I have used will vibrate when powered on. This serves two functions:
  1. Tests the vibration motor
  2. Notifies the user that the phone turned on, in case it was an accident you wanted it off to save power.
First, remove any recently installed apps. If that doesn’t help, I recommend trying a wipe of the cache partition. This will clear out a bunch of temporary data and, although it will cause a slower boot-up the first time after being performed, will usually result in a much more responsive phone later.
Here are the steps:
  1. Turn off the device.
  2. Press and hold the Volume Up key and the Home key, then press and hold the Power key.
  3. When the logo screen displays, release only the Power key.
  4. When the Android logo displays, release the Volume Up and the Home key ('Installing system update' will show for about 30 - 60 seconds before showing the Android system recovery menu options).
  5. Press the Volume down key several times key to highlight 'wipe cache partition.'
  6. Press the Power key to select.
  7. Press the Volume down key several times key to highlight 'yes.'
  8. Press the Power key to select.
  9. When the wipe cache partition is complete, 'Reboot system now' is highlighted.
  10. Press the Power key to restart the device.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
Try opening your device in safe mode. If it’s fine and everything, it’s likely an app like you said. If it persists, then you know it’s a different issue.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
You know that this post was a year ago.
I now own a Galaxy S9+ which doesn't do it.
さんによる
My bad dude.
さんによる
コメントを追加
Why does my phone vibrate when I turn it on?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
My Name さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 8
過去 30 日: 47
今までの合計 4,461
