メインコンテンツにスキップ
Amazon Fire HD 8(第5世代)は、2015年9月にAmazonから発売された洗練された黒いタブレットです。モデル番号:SG98EG。
38回答 すべてを表示
Why is my Kindle Fire acting so weird?
So... My Kindle have been acting odd for a while. It first happened about a month ago. I Was watching youtube and then it turned off. as it was turning off, I glanced at the charge button, and it said 0. I Let it charge a while, got back on, and it was all fine. It happened a few more times, rinse and repeat. Until yesterday. It happened again, so I decided to let it charge while I went to sleep. This morning, however, it wouldn't turn on. I Held down the button a few times, double pressed it quickly, but no matter what I did, it wouldn't activate. I'd love some answers, as I have had this for a while, and have a lot of personal images saved onto it
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
@inkiii this "glanced at the charge button, and it said 0" and the subsequent failure at a later time suggest that your Fire either has a depleted battery that no longer accepts a charge or you are having an issues with the charging port or power management IC circuit on the motherboard. I would start by replacing the battery. Use this guide Amazon Fire HD 8 バッテリーの交換 for that. That will at least give you a known-well starting point should further troubleshooting become necessary.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
I'll try that. Thank you so much!
さんによる
コメントを追加
回答を追加する
LittentheKitten さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 3
今までの合計 414
