メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
The first generation of the Chevrolet Equinox, a crossover SUV from Chevrolet based on General Motors' Theta platform.
Why does my engine make a noise when my vehicle idles?
My equinox runs great except engine makes a strage noise when the vehicle idles at stoplights and such. At first we thought it was the air conditioning compressor which is giving trouble, but it does it when the air is off too.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
4 件のコメント
Would you describe the noise?
さんによる
It is almost as if the driver is lightly mashing the gas with the vehicle in park only no one is mashing the gas and the vehicle is in drive with the driver's foot on the brake. It doesn't do it everytime, only randomly.
さんによる
I took it to three different mechanics and they all told me something different. The first one said it was the air conditioner. He also put it on the comupter and didn't get any codes. The second one who is the air conditioner guy said it was the torque converter and sent me to a different guy. The third one somewhat agreed with the first one and said it was the air conditioner. What I don't understand is why it is fine in park and only does this when the truck is in drive and is worse when going in reverse. I tend to agree with the second guy that it sounds like something to do with the transmission. Since it is a cross over vehicle you can't check the transmission fluid to see if it is low. My question is, should transmission problems show up on the diagnostic computer?
さんによる
I have a 2020 Chevy Equinox . Mine did the exact same thing. They changed out the turbo booster.
fixed it !
さんによる
コメントを追加
6件の回答
ベストアンサー
Go to Auto Zone and get them to hook up their diagnostic machine. There's no charge.
このアンサーは役に立ちましたか?
スコア 4
コメントを追加
Vanessa, I believe that even with the air off you can still get a surging of the engine due to a coolant loss in your system. So if you are having compressor issues, I would not totally rule it out. Of course there are 100's more possibilities for this type of symptom, so like mayer says, good idea to get it on an engine analyzer and see what it will tell you.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
GM has a TSB on this problem. Take it to your dealer and they will fix.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Take it to a gm dealer they have a better scan tool and it Prolly won't tell u anything if the lights not on at autozone its just a code reader the tech 2 is a much better tool
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
It may be your idler pulley or your water pump. I had the same issue. Both are relatively easy repairs and inexpensive. You can probably do them yourself with some youtube videos. Take your serpentine belt off and run your vehicle see if you can hear the noise more clearly. Turn off your engine and spin both the idler pulley and the water pump to see if they make crazy noises without the belt.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Mine still does the same thing, it is the muffler flex pipe from the engine manifold that makes contact on the front stabilizer bar. They just didn’t leave enough room for the vibration of the engine, mostly at idle. You could remedy this by adding some high heat tape, I just didn’t bother.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
My 2012 Equinox ma kik es a rattling noise as well its frustrating, some says it chevy some tell me my car sounds like crap! Help I don't know what to do
さんによる
コメントを追加
回答を追加する
Vanessa さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 14
過去 30 日: 71
今までの合計 38,207
