メインコンテンツにスキップ
Dell SFF desktop introduced for the home market in 2007.
11回答 すべてを表示
replacing WN097 - Inspiron 530s audio and front usb ports IO Board
I have done some research and found that it is relatively easy to replace, simply just plugs and screws. but when i search for the part to buy i see Model: vostro 200 dell inspiron 530s. I am worried about the "vostro 200" part making uncapatable with my pc. does anyone know if it will be compatable
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
@thebuck2613 why would that worry you. It is not uncommon that parts are cross compatible with other models. After all, the Vostro 200 is just another Dell computer. If you are really unsure about what to do, I would ensure that wherever you buy it from has a return policy.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
i know some things on electronics can be very picky and ive not went this far into my pc before. the most ive done has been installing a cd drive.
さんによる
コメントを追加
回答を追加する
jon buckingham さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 4
今までの合計 94
