メインコンテンツにスキップ
2015年9月にAmazonより発売された、7インチマルチタッチスクリーンディスプレイを搭載したタブレットです。モデル番号はSV98LNです。
50回答 すべてを表示
Where's the Internal Memory Chip on the Motherboard
Well my Kindle Fire finally took it's last breath today & I took it to a tech repair store to see if I can get the memory on it moved over to a new Kindle Fire.
They told me they could swap my old motherboard out & into the new Fire, but they also told me if it was a problem with the motherboard then it wouldn't even be worth it because it would cost me around $500 to find the SD card on the motherboard & to copy it over or something like that.
So I was wondering were the internal memory is on the motherboard so I can see if that would help them move over the information or not. And drive down the price because that's just insane.
Thank you for taking the time to read this & if you gave me an answer.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
@d4rk1ight should be a Samsung Flash Memory IC under the EMI shield. If you remove those shields from your board and post some images of your board, we can identify the IC for you. Use this guide iFixitでの質問に画像を追加する方法 to post some images with the shields removed.
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
Sadly there is no swappable SD card here it's a soldered chip.
Maybe the cheaper way here is to just get another Amazon Fire of the same generation (used) thats working to try swapping out the logic board if you're up to it. Here's the IFIXIT guide: Amazon Fire 5th Generation Motherboard Replacement.
さんによる
コメントを追加
回答を追加する
Christian さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 7
過去 30 日: 21
今までの合計 1,413
