Why is my disc slot flashing blue?
Why is my disc slot flashing blue very fast? I know that it is definitely not because I have a new message. I know what that looks like. This is very different.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
When the blue light is on, it indicates that your Wii is connected to either a wireless or wired LAN and that the Wii has downloaded new data. That data could be an email message, a system update, or some other type of information which you should review and act upon.
This light indicator feature is part of WiiConnect24. This allows your Wii console to receive a wide variety of data automatically. Use the WiiConnect24 settings to turn WiiConnect24 on and off. Turning it on allows you to enable its Standby mode to receive data automatically 24 hours each day, even when the system isn't in active use.
There are three options for the slot illumination:
Bright: The Wii's Disc Slot will blink bright blue when WiiConnect24 has received new data.
Dim: The Wii's Disc Slot will blink a dim blue when WiiConnect24 has received new data.
Off: The Wii's Disc Slot will not blink when WiiConnect24 has received new data.
Here's the operating manual.
このアンサーは役に立ちましたか?
This is not what is happening. I understand the WiiConnect24. This is very different. This is a very severe problem because not only does the disc slot blink blue very very fast but the wii will not turn off when this happens and nothing shows up on the tv screen while this is happening. I repeat it has nothing to do with WiiConnect24.
Try these steps!
Insert a Wii Balance Board compatible game disc in the Wii console.
Use the Wii Remote to select the Disc Channel from the Wii Menu, then select "Start" to begin the game. Press the A Button to bypass the wrist strap screen.
Open the small SD Card slot cover on the front of the Wii console.
Remove the Battery Cover on the bottom of the Wii Balance Board.
Press and release the SYNC button on the Wii Balance Board. The blue light on the board will start blinking.
Press and release the red SYNC button on the Wii console while the blue light on the board is still blinking.
The blue light will stop blinking and stay on steady once the syncronization is complete.
Thank you for your help but this is not what my problem is. I do not own a balance board and do not have any games for the balance board. I wish I Could post a video of what is happening because then you could see what I am talking about. The it basically seems like it is the equivalent of the red ring of death for the XBOX but for the WII because when it is flashing I cant do anything with the wii like I cant even turn it off, i have to unplug it from the wall in order for it to stop flashing. while it is flashing it also is frozen on the screen and it will not advance from the first screen that usually comes up when turning on the wii.
Sorry, I'm just not able to help you. Perhaps you should go directly to Nintendo foe support help, here's where: http://www.nintendo.com/consumer/index.j...
Thanks for the info
The reason it's flashing blue is because you have unread messages. You can turn it off in the wii settings.
このアンサーは役に立ちましたか?
Because it tells you if the disk is being read or not
このアンサーは役に立ちましたか?
This seems to be the closest answer. Mine will is stuck with a disc inside and never actually turns on, constantly flashing every time I press the power or reset button.
Turn your Wii on and check if you have an update ready to install or if you received a measage.
このアンサーは役に立ちましたか?
My Wii started flashing slowly from bright to dim, basck to bright, etc. as soon as I synced it to my Club Nintendo account. I believe that kind of flash has to do with it. As far as it being online, when you connect it to the internet, the standby light will become orange instead of red.
このアンサーは役に立ちましたか?
For the person that said they watch Netflix, it's because you got a message. It might've even been 2 years seens you got the message. Turn off wii conect 24 and if that does not work the go to message board, then at the bottom left you will see a calender, click that and check all the days seems you've had the wii and delete all the yellow mail envelops. An if its happening offline then you go to settings- wii connect 24- and turn all the settings to off. Hope this helps! Good luck!
And if that does not work, send it in or get a new one or even the new wii u.
このアンサーは役に立ちましたか?
I guess you could... There is a application for the HBC that will do that. Or just don't be lazy and ####ing do it. Finally, you can delete your messages entirely from the app for the HBC called Message Be Gone...
このアンサーは役に立ちましたか?
If your disc slot is blue,You should go to playcon messages and check out your messages to see if you have to many.If not,I don't have anymore information for you.
このアンサーは役に立ちましたか?
if it isnt anything here, you should definitely get it fixed. your console is f****d.
このアンサーは役に立ちましたか?
My console did this, but it was not wiiconnect24. it was a part of the motherboard that broke off and i cant find a way to get a replacement or a fix. its an orange part above the cpu/gpu on the gamecube port side.
このアンサーは役に立ちましたか?
過去 24時間: 10
過去 7 日: 71
過去 30 日: 315
今までの合計 120,871
did you get an answer? mine is doing the same?
Cindy Cindy さんによる
i have the same problem...im not connected to wifi or anything and i dont have a balance board...sometimes its a lil loud when its running and my blue disc slot lights up randomly until i unplug the power from the back.
danielle さんによる
I am having the same issue. We were watching Netflix and the blue light was on and it blinks. Now with the console off the blue light is still flashing. Wish I knew why.
coachmom84 さんによる
I encountered something similar. I installed Hulu+ and Netflix on mine last night and it started to have the blue light on all night, even after I turned it off. It goes bright, then slowly dims, then brightens up again. I feel like I'm in a hotel at Vegas with the lights dimming and flashing in my room. What does that mean?
Raw さんによる
I have same problem today when I turned if off.
Ashlie Smith さんによる
9件以上のコメントを表示
