screen lights up I cant Scroll to unlock
italic text I have a 3rd Gerneration ipod touch . the screen and evverything lights up , but when i "scroll to unlock" it Won`t respond .
この質問は役に立ちましたか?
この質問は役に立ちましたか?
How to unfreeze or reset an iPod Touch
To reset iPod touch, press and hold the Sleep/Wake button and the Home button at the same time until you see the Apple logo show up on the screen:
How to unfreeze or reset an iPod Classic
1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
2. Now press and hold the Menu and Select buttons until the Apple logo appears, which may take about 6 to 10 seconds. You may need to repeat this step.
Notes:
If you are having problems resetting the iPod, go ahead and set it on a flat surface. Then make sure the finger pressing the Select button is not touching any part of the click wheel. Also be sure that you are pressing the Menu button towards the outside of the click wheel, not near the center.
If the above mentioned steps do not work, then you can try connecting your iPod to a power adapter and plug the power adapter into an electrical outlet, or connect the iPod to your computer. Make sure the computer is turned on and isn’t set to go to sleep.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 2,290
