I have sony X wont take photos in the back and front camera
i have sony X wont take photos in the back and front camera what can i do to fixit i tryd to fix by software but still the same
The camera may damaged and got some issue after a long time of using. You can try reconnect the camera flex cable, cause the flex cable maybe loosen when accidentally drop or hit.
However, if reconnect the flex cable can not fix the camera problem, then you should change a new camera.
This Sony Xperia X Rear Camera Repair Guide and Front Camera Repair Guide can help you replace the camera.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 3
過去 30 日: 8
今までの合計 75
