Manuel transmission 1999 Saturn sl, replace
5 speed Manuel trans replacement
この質問は役に立ちましたか?
William Emerson excellent write up about the how-to on here. Definitely not an easy job. I would also recommend that if you need more information on this extensive task, visit your local library and see if they have the manual.
このアンサーは役に立ちましたか?
Thank you for your help, I have a 1999 3 door Saturn 5speed Manuel trans, mine is broken looking for another one
William Emerson not sure where you are located. I would connect with a local recycler. I guess that's what they call the wrecking yards now. Even if they do not have it they can probably find one for you.
過去 24時間: 0
過去 7 日: 1
過去 30 日: 4
今までの合計 96
