How to rewire fuel injector connector
my fuel injector connector on a jetta a4 mk4 broke and need to replace connecor, how do I remove the wire terminal from the connector to insert into new connector..
この質問は役に立ちましたか?
この質問は役に立ちましたか?
I'm not familiar with that specific connector but its likely it will be the same style as the ones in this video:
https://youtu.be/lrs8-KtJGus?t=56
You might inspect the old, busted, connector to get an idea of how it releases. Some different connectors have the wire come out the front of the connector.
I've seen people use hair pins and skinny screwdrivers to get the 'primary locks' released.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 5
過去 30 日: 12
今までの合計 2,833
4 件のコメント
The connector on the harness? Or the connector on the injector?
Cameron さんによる
connector on the harness, which is this type: 06a973722
https://volkswagen.7zap.com/images/Tnrpi...
Rochin さんによる
See this thread for reference pictures. Very likely once you pull the locking tab forward you'll insert a tool into the small hole above the pin to release the detent.
http://forums.vwvortex.com/showthread.ph...
Phil さんによる
It would be best to replace the wiring harness for the injectors you can get a cheap one at your local auto wreckers
Jimfixer さんによる
