メインコンテンツにスキップ
Released May 2015, identified by model number SM-T350. Features 8.0″ TFT capacitive touchscreen, 5 MP camera, Wi-Fi, GPS, Bluetooth.
118回答 すべてを表示
Why does my tablet overheat and restart?
So, I have had my Galaxy Tab A for almost a year now and his is the only issue I'm having. My tablet will be hot to the touch (sometimes not) and will the commence to shut off instantly and then right after restart. After it turns back on, the issue will usually reoccur within 3-5 minutes. Also, when I change it, it will have absolutely no issue. To add, it will charge very slowly. This version have will not let me access my internals. Send help fast!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
最も参考になった回答
No. This is unfortunately not the issue. It will have the issue at idle to.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
It's most likely because you leave to many apps open and your device can only have so much make sure when you close a app that it's not still going in the backround of your device!
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
It has been almost a decade, and still Samsung has not addressed the issue with overheating. My advice is to follow the many others and buy another brand. I have heard of Samsung soaking thousands of dollars off customers in cascading repair bills... plainly because their product is defective in its design. So bottom line... don't buy Samsung!!!!
さんによる
コメントを追加
回答を追加する
UnlimitedREKT65 :P さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 6
過去 30 日: 30
今までの合計 3,146
