Transmission not shifting into gear
3rd and 4th gears grinding and not shifting into gear
manual? try pushing the clutch in all the way lol, check your fluid, check for possible overheating via grinding during shifting, or clogs in the trans cooler lines.
Automatic: THERE IS A RECALL FOR THIS, IF THAT CABLE BREAKS YOU CANNOT CONTROL THE TRANSMISSION
このアンサーは役に立ちましたか?
auto: check in a code reader or with ALFAOBD that the shift solenoids are functional, or have a shop look at it entirely
過去 24時間: 0
過去 7 日: 2
過去 30 日: 12
今までの合計 227
