Is it possible to replace xbox one x psu with an ATX psu?
I want to replace the internal psu on the xbox one x with an atx psu that you'd use on a PC.
I can see by the teardown video that the internal psu connects to the motherboard via some kind of proprietary connection, would it be possible to somehow connect the required wires from an atx psu to that motherboard power connection point? Perhaps you could dismantle the xbox psu and use the wires from inside it (connecting to the proprietary part) to solder the atx wires to.
I know if you could somehow work past the proprietary connection point, an atx psu would definitely be able to power an xbox considering it's been done to previous generations without any problems. Thanks for considering :)
この質問は役に立ちましたか?
1件のコメント
What will it bring to add an ATX psu? I’m just curious
tregouetsylvain さんによる
