Why is my replacement screen unresponsive?
So I got a replacement screen and after installing it I ran the itunes restore and update since the phone was in a disabled state. This would be a clean install with iOS 11.1, not from backup. Anyway, the screen functions except when it first boots up. Once it boots up to the home screen (no passcode or touchid) you can't swipe or press icons. The only way it will work is if you press the sleep/wake button twice (first time it goes off, next press it comes on).
I've tried adding security to it to see if that made a difference but it doesn't. Another bizarre thing I noticed was that if you reboot the phone using the Sleep/Wake + Volume down and release both buttons when you see the Apple logo, it boots to the home screen like normal and works just fine. No need to press sleep/wake button twice. It's only if you shut down the phone using the sleep/wake button and then slide to power off and then turn back on do I get this problem.
Don't have any other screens to try or else I would :(
UPDATE** Got another screen from a different company (Corepair from Amazon) that was a full assembly. I've used this companies screens a lot and never had an issue. Anyway, this screen does the exact same thing as the first one I had. I've made a video to show what I am experiencing: https://youtu.be/hkqgrU2_fgI
Just found something that may be of value. If I shutdown the phone normally, when I turn it on it boots to the Home Screen and the touch screen is unresponsive (until it goes to sleep or if I press the sleep/wake button twice). If I hard reboot the phone holding down the Sleep/Wake + Volume Down buttons, the phone boots to the lock screen and is responsive...
Matt Clark さんによる
Hey everyone. I created a video to show you the issue. Since the last time I commented, I received a different screen from another company and it does the same thing. Just stuck at this point.
Matt Clark さんによる
