メインコンテンツにスキップ
統合されたディスプレイを持たない一般的な据え付けのコンピューターです。
2134回答 すべてを表示
bios blank,post desktop screen blank,displays from desktop .
when i turn my pc fan works,lights works,everything works but display is blank as nothing is happening but in background everything is working even the window loads in the background but doesen't display after the window loads in the background then i it displays from the desktop welcome screen with the cursor and everything is perfect from browsing to playing games etc. the only problem is that the screen is completely blank before the desktop welcome screen(not even bios,windows loading is visible,no beep qas well).after turning i tried press f2 for boot menu but it displays blank but in backgroud bios gets on then to restart i had to press esc key and then Y and enter to exit the bios with my personal experience and it gets restart.
following are the specification
'''inter core i5 4th generation
gigabyte motherboard b858m-d3h-a
8gb ram
1tb hard disk
windows 7 ultimate operating system'''
i tried re inserting th ram by cleaning the dust
i tried removing the cmos battery for 2 hours and placed it back
i tried replacing a new cmos battery
i tried updating all the driverbut nothing works please help me and please explain the problem solution in breif sir so that i could fix it as soon as possible as i need to access my bios
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
It sounds like the problem is with the monitor, not the PC. It's as though it's unable to display the default resolution and refresh rate used by the BIOS. See if you can find something in the monitor settings, or try a different monitor.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
The problem occurred few days back before it was displaying everything i did changed the resolution setting as well and refresh rate to 60 to 70 to 75 but still the problem is in action.
さんによる
コメントを追加
回答を追加する
Rizwan Rey さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 3
今までの合計 351
