メインコンテンツにスキップ
モデル番号はA1238/80、120、160GBハードドライブ/ブラックもしくはシルバーメタルフロント
904回答 すべてを表示
Water damage to iPod, then plugged it in, maybe fried!
My son threw my ipod in the toilet...i took it out and dried it off and it seemed to be working fine...at the moment i was cleaning and I like to listen to music...so i put in on an ipod player and it played fine...but then later on...it started over heating and now it doesn't power on or do anything...can this be fixed???
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
4件の回答
最も参考になった回答
I am inclined to agree with Jacques Richer, except my preference is to clean the logic board with isopropyl alcohol and a soft brush. LEt it dry and definitely check for any corrosion around the components or your logic board and the cable connectors as well. I am a strong believer in replacing the battery after any water immersion. Probably based on my experience with lithium and water. So that is where I would start and then revisit the issue as they arise. Good Luck to you.
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
Possibly. I've had a fair bit of success handling problems like this by carefully removing the case and allowing it to dry for 2-3 days. Overheating is an overcurrent problem, so the chances are pretty good that this will work.
Your chances can be noticeably improved by removing the battery and washing out the rest using deionized water (available at grocery/health food stores and major pharmacies). This will help remove any contamination from the water in the toilet.
Case removal directions: iPod Classicのバッテリー交換
The reason I suggest deionized water: The existing contamination is water soluble. It may not be alcohol soluble. If you want to try alcohol, do it after a few good flushes with deionized water, since that will handle salt contamination. Alcohol is great for helping you get the last of the water out.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
How do I take off the case from the ipod...it seems impossible. It's the 160gb 6th gen IPOD classic..
さんによる
hi, Shaneeza. Maybe the link i have posted in my answer can help.
さんによる
コメントを追加
Hi, I agree with the answer from oldturkey03, and just want to add that it might need more than one cleaning before it decides to return to order. In this forum you'll find repair-guides and you can browse answers to similar questions using the tabs to the right on this page.
If you get stuck trying to getting the iPod opened I've made this post that might help:
http://shadowofcertainty.blogspot.com/20...
good luck
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
+ Good job on your blog.
さんによる
コメントを追加
try resetting it by first pushing the menu then push and hold the select key while toggling the hold button back and forth a few times ,continue holding the center select button aprox. 10 more seconds or until the apple icon appears.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Shaneeza Akim さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 4,259
