1993 Intruder vs 1400 wiring
What to do with the wiring plug ins beneath passanger seat on the fender after it has been bobbed. If you leave the seat off the wires are exposed. Can these wires be relocated?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
@larrylambing post some images of where your wires are right now. I am sure that this can be done with either hardwiring and using shrinktubing to protect them form short circuiting or by using a connector. It depends on what connector/wires those are. Check against the wiring diagram for the VS1400.
We need to see what you see, for that use this guide iFixitでの質問に画像を追加する方法
このアンサーは役に立ちましたか?
過去 24時間: 3
過去 7 日: 21
過去 30 日: 96
今までの合計 2,946
