メインコンテンツにスキップ
The Pontiac G6 was a midsize car that was produced by General Motors. It was introduced in 2004 for the 2005 model year to replace the Grand Am.
18回答 すべてを表示
2007 Pontiac G6 Gauges go crazy or stop working. Car bucks and jumps
Out of the blue the gauges start going crazy or stop working all together. Car bucks and jumps. Dealer said it was a loose ground wire and it worked for about 2 months and then the same old thing. Only has 70,000 miles.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Hmm. A bad ground connection usually causes the needle in a gauge cluster to fluctuate unnecessarily. It is possible your ground connection got a bit too corroded and is causing your problems. If you know where the ground wire was previously tightened, try cleaning up the oxidation around that connection and seeing if your problem goes away. If it does, hit that spot with spray paint to prevent further rusting. It is possible the location on your wiring harness that connects from the (-) on the battery to the frame is corroded or a part of the wiring harness insulation has become exposed.
Remember, a car battery can kill you. When working on a car wiring harness, make sure to remove the wires from the battery terminals and isolate the battery terminals with electrical tape. Sometimes it's a good idea to replace the battery terminals if they become too corroded / oxidized or deformed.
Good luck.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Kevin さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 6
過去 30 日: 31
今までの合計 3,122
