メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2016年9月16日に発売。モデル番号は1778,1784。 GSM かCDMAの32、128、256GBがあり、色はローズゴールド、ゴールド、シルバー、ブラック、ジェットブラックがあり。
iPhone 7 plus Camera not working after screen replacement
Hi,
I've just replaced screen iPhone 7 plus for a customer, after that she checked and both front and back camera are not working(I don't know if she broke before or I did it). I have tried to reseat front camera but no help. I replaced aftermaket front camera and it won't work too(I heard aftermarket camera won't work on ios 11???). I haven't tried original camera yet. PLease let me know what happen?
Thank you very much!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
1件のコメント
I have a problem with iPhone 7plus camera it had changed the screen and battery but my camera it doesn’t focus when its on photo it shows shaking quality pictures but if i put on portrait its clear picture
さんによる
コメントを追加
2件の回答
最も参考になった回答
Hello,
I would recommend an original camera as they tend to always work. You can find these on eBay and ifixit but if you are searching on eBay put in a genuine Apple iPhone 7 plus camera. The best ones that I use are used but high-quality new parts are available on ifixit. Here is the link: iPhone 7 Plus Dual Rear Camera
iPhone 7 Plus Front Camera and Sensor Cable
If an original part doesn't work then this may be a motherboard problem. Also, have a look at the connectors and the connections you are making to the board=. Sometimes they can be a bit off and make a problem. Hope that helped
Replace a front camera and sensor cable compatible with the iPhone 7 Plus. Includes the front-facing camera, one microphone, and the proximity sensor. Part #821-00519-03.の画像
製品
$29.99
Replace a dual 12 MP rear-facing camera compatible with the iPhone 7 Plus. Fix focusing or sensor issues.の画像
製品
$17.99
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
try disconnecting the front camera and powering the phone on, if back camera works then its your front flex or connection
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
kardon3000kardon さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 31
今までの合計 4,432
