Will not power up. Does not show up when plugged into computer
Will not power up. Does not show up when plugged into computer. tried new batteries and taking them in and out a bunch of times to try and reset. no lights at all
Ephiram Bosse time to take a closer look at it. you do want to check the battery connections to make sure that the battery provides power on the connector. After that you want to check the micro USB connectors on the motherboard to make assure all of that is connected/soldered. Post some pictures of your boards so we can see what you see. Use this guide iFixitでの質問に画像を追加する方法 for that and use this guide GoPro Hero3+ Black Edition Motherboard Replacement to work on your GoPro
ガイド
難易度:
とても簡単
2 - 5 minutes
ガイド
難易度:
中レベル
10 - 15 minutes
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 1
過去 30 日: 6
今までの合計 63
