メインコンテンツにスキップ
Meizu社によって製造された修理ガイドならびに製品サポート
36回答 すべてを表示
Meizu MX4 screen replacement: what gasket to use?
I broke my MX4 screen and I need to replace it, I saw that around the display there's a rubber gasket, I think that the screen is attached to the frame thanks to this gasket. I have been shooting this photo, where you can see the gasket between the display and the frame.
What kind of material is this? and where I can buy it? I think that it isn't 3M tape, it's like a seal.
You can see the gasket in this video at 5 minutes and 45 seconds, the guy in this video cut the gasket with a cutter.
Thank you.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
選択されたソリューション
I solved, the seal is called "Zhanlida T-7000" glue, it's a siliconic black glue that I used to seal the screen and restore it. I bougth this glue on Amazon, but also it's available on ebay.
Hope that this answer can help other people.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Marco さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 130
