メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
HP Pavilion g6-1b79dxは、2011年に製造されたピューター仕上げの15.6インチノートパソコンです。内蔵ウェブカメラとIntel Core i3プロセッサを搭載しています。
Unable to delete 0 byte file.
I was playing with batch files and accidentaly created a 0 byte, no extention file.
画像
I googled the problem and I found out that closing explorer.exe and deleting the file via command would help. Tried that. It didn't help. Any software that could do it? Any other suggestions?
Thanks for your help in advance :)
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
7 件のコメント
Honestly, if its doing no harm to the laptop, you should probably just leave it.
さんによる
It's taking up space on my desktop. I need that space :(
さんによる
I would suggest using an administrative login to examine the file permissions. You need to open up the permissions and try the delete again afterwards. Windows file system permissions can make you want to resort to violence at times. Use of cygwin can help sometimes when all else fails.
さんによる
If its just taking up space on the desktop, you can set the file to be hidden so you cannot see it unless you have view hidden files enabled. also what is this File Unlocker thing mentioned in the file description?
さんによる
@professorc I doubt changing the permissions would do anything. Cygwin on the other hand might. I'll try that. Thanx for your help.
さんによる
2件以上のコメントを表示
コメントを追加
2件の回答
ベストアンサー
As I stated earlier.... Windows file system permissions can make you want to resort to violence at times. Use of cygwin can help sometimes when all else fails.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
最も参考になった回答
Create a new profile in Windows with admin privileges.
Log out of the current profile.
Log into the new one.
Use explorer to go to your other profiles desktop location.
Manually delete that file.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
Thanks for your answer but explorer.exe simply does not see the file as... a file. Creating a new account would probably do thesame as killing explorer.exe and deleting the file via cmd which did not help as I said in the question. Thanks anyway.
さんによる
From the new profile open a new profile, open a command prompt with administrator privileages, and then use command prompt to navigate to where the 9 file is. Then "rmdir /s <file name> or del <file name>.
さんによる
コメントを追加
回答を追加する
SLimy さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 7
過去 30 日: 21
今までの合計 914
