メインコンテンツにスキップ
2012年9月12日に発表されたApple社による6番目となる iPhone。このデバイスの修理方法は前モデルと類似しており、スクリュードライバーと開封工具が必要です。GSMかCDMA方式、16/32/64 GB。 本体色は黒と白。
2522回答 すべてを表示
Rear Camera Problem - SW or HW problem?
Hello,
I've got an iPhone 5, It's old, I know, but I'm (was) happy with it.
I've got a problem with Rear camera - see picture.
Sometimes It's working, sometimes it's just black screen (most of the time) and sometimes problem showed in picture occurs.
I have replaced rear camera, restored the phone (deleted, then set it up as new, downloaded apps from App Store)
I don't know what to do next to fix it - is it software problem, or hardware?
It seems like software problem - camera works after restart, but when I start using some of my Apps, it stops working. Then only front camera works. When camera is not working, torch (LED flash) doesn't work too.
Thanks for help,
Dominik Pecháč
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
ベストアンサー
Do you know if the replacement camera was working or was it purchased new? Using known-good parts is important for troubleshooting and "new" cameras don't all work either.
With a complete reset of your device, I highly doubt it's a software issue. If you can get your hands on a known-good camera, that will help you determine if the problem is with the camera or the logic board (which is what I suspect). Have you dropped your phone recently or has it been repaired or come into contact with water?
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Replaced camera was working (took out from other iPhone)
Phone was dropped sometimes, this problem occured sometime in june/july.
I don't know about some contact with water, except little rain or sweat, no visible corrosion on motherboard. I'm repairing my devices by myself.
I will try to reset it again and use without any apps and see what will happen. I sucpect Snapchat of making this problem. I will see.
Thanks,
Dominik Pechac
さんによる
コメントを追加
回答を追加する
Dominik Pecháč さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 145
