メインコンテンツにスキップ
The ZTE ZMax Pro is identified by its black color, rear fingerprint sensor and its model name, Z981, which can be found under the rear case.
133回答 すべてを表示
My phone keeps unplugging itself
A few months ago, my charger broke so my dad had bought me a new one from Metro PCS. That stopped working a few weeks later, so I got another one. I've had it for a few weeks now and it did fine, but now for some reason it'll randomly stop charging by itself. Now, it's an easy fix in the moment. All I have to do is replug it. But this gets really annoying when i leave expecting my phone to be charging(let's say, while I'm sleeping and waiting for an alarm for example)
Any clues on how to fix this would be great, thank you!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
check if it does the same with another charger, or just test it with usb cable im sure you have one around. if it keeps doing the same thing is your charging port the problem. i would also recommend doing a backup of all your data and formating the phone then restore data for last tip. hope your phone is not the problem.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Alicia Gomez さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 4
今までの合計 101
