メインコンテンツにスキップ
Apple AirPodsは2016年12月に発売されたワイヤレスヘッドホンです。
Help I washed my airpods in a washing machine
Guys my AirPods and airpods charging case I washed it in a washing machine bymistakely forgot I had it in my pocket help…the green led light is not illuminating it doesn't work help if any one has any solution about it plz do share
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
ベストアンサー
My suggestion would be to put them in a bag of rice overnight. The rice will help draw out the water. If this doesn't work then I'm afraid you will need to buy a new pair since the water has likely killed the electrical components. It might also be worth letting them stay in the bag of rice for a few days. Good luck!
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
That is a myth. Rice is not a desiccant, and only blocks air flow. Keep them warm with a lamp and fan.
さんによる
I save those little packets of stuff that keeps stuff dry hahaha u know the little bags of it says don't eat blah blah n I have a med bottle full I used bef
さんによる
コメントを追加
回答を追加する
Ali さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 20
今までの合計 27,655
