メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
30 amp fusible link blown
The fuse box under the hood has a 30 amp fusible link that is blown. I replaced it and blew again, and was told by friend to replace the fuel pump. Engine turned and problem seemed to be solved but happened again when I closed the hood. Found the right turn signal had a blown wire just behind the light. Since the fuse has not blown but I am waiting for it to happen again.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
@estgarcia85 since it is working for now you may just have resolved that issue. If it happens again, you'll have to check again. Problems like this are really hard to resolve since there is always more than one possibility. Post a picture of this "fuse box under the hood has a 30 amp fusible link" with your question so that we can check the wiring diagram. Use this guide to post images with your question iFixitでの質問に画像を追加する方法
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Esteban Garcia さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 15
今までの合計 857
