メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2012年、Sony Entertainment は2006年 Playstation 3コンソールの新モデルバージョンを発売することを発表しました。この新コンソールは、Playstation 3 Super Slimと呼ばれ、モデル番号はCECH-4000です。PlayStation 3 Super Slim (CECH400x) はSony Computer Entertainmentによって製造された第三番目のPS3ビデオゲームコンソールです。2012年10月25日に発売されました。
rare problem when inserting discs
hello folks, I have a problem, in my console when I insert a game only the laser turns on but the motor that makes the disc move does not rotate, what I did is to put the ribbon cable that goes under the motor to the other side and when putting a disc now if it rotates, but it changes speed so it never reads the game. I saw the ribbon cable and you see a separation in the contacts, as if it had broken, the problem is only the 9-pin ribbon cable and the rest is fine ?? sorry for my bad English, is that I do not speak English, thanks in advance!
EDIT: Here are some vídeo footage about my problem https://youtu.be/nP7hH0BO_bk
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
Try to get a new ribbon cable and replace the cable. u can probably find one online somewhere, shouldn’t be too expensive
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
I'll do it as soon as I can, plus I forgot to say that the lidsensor ribbon cable was also broken so, to do the test I pulled the cable from the power button and inserted it into the lidsensor, thanks for answering since I started with the intrigue that the logic board had been damaged but I corroborated that theory since I have some demos on the HDD and if they work, I also thought that the disk engine was damaged, which would be strange since I rarely played on the ps3, and when I was going to start playing more often since I got the saints row 3 and that problem occurred, if the problem is solved, I'll give you the points !, if not, I will notice anything in case someone will have this problem
さんによる
Hi dude, look at this, its my problem https://youtu.be/nP7hH0BO_bk
さんによる
コメントを追加
回答を追加する
[deleted] さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 8
今までの合計 351
