After screen replacement stuck in charging battery screen
Hello all,
Ipad fixing noob here. So I did a front panel replacement on this ipad since it had a cracked screen. All went well, and the ipad worked briefly, but the as the battery drained and is dead now -- the ipad wont charge back up.
I have a usb ammeter that shows 0.12 A while charger cable is plugged into ipad, and when I press the power button and the battery screen shows the amps jump to 0.6 A. Not sure about this behavior. I believe iPad is supposed to draw 2A max, I have it plugged into macbook pro.
As I was peeling up the old cracked screen I noticed what I believe is the 4G unit came up with the screen.
Here are some screenshots for reference:
この質問は役に立ちましたか?
