メインコンテンツにスキップ
2015年3月にアップデートされたAppleのMacBook Pro 13" Retina Display Early 2015 はモデル番号はA1502、第5世代のIntel Core i5と i7プロセッサーが特長でForce Touchトラックパッドを備えています。
1185回答 すべてを表示
Beeps 3 times won't boot soldered RAM A1502 MacBook 2015
Beeps 3 times and doesn't not start up. RAM is soldered so I can't re-seat or clean and place it again. Please help, how to solve this problem when the RAM/memory is soldered in the logic board. Thank you.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 3
コメントを追加
2件の回答
最も参考になった回答
Sadly, you need a new logic board. I would go to an Apple Store and give them a piece of my mind!
Do make sure you didn't get your system wet or have big dents in your system.
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
Thanks, Dan for your answer. The MacBook doesn't has any dent and wasn't wet. Any suggestion which part of chip/component I need to replace in the Logic Board to fix this problem.
If this is a logic board issue, please let me know which component of in logic board do I need to replace. The RAM seems fixed/soldered in place so, by good guess that RAM should be good.
さんによる
Not so simple! Any one of the RAM chips could be bad or the PCH. I can't tell you which chip. Thats why you need a new logic board.
Apple owes you here! If you push they should replace it for minimal cost.
さんによる
コメントを追加
Hi Adrian,
As @danj said, you most likely will need a new logic board. If you can get Apple to fix it for free or relatively cheap, go that route! However, if you are unable to get the help you need from them, we sell 3 different models of logic board for your particular machine, depending on which sub model you have. They aren't cheap, but they will fix the problem:
2.7 Ghz Logic Board
2.9 Ghz Logic Board
3.1 Ghz Logic Board
Good luck with the repair!
- Jasen
MacBook Pro 13" Retina (Early 2015) 2.7 GHz Logic Boardの画像
製品
$199.99
MacBook Pro 13" Retina (Early 2015) 2.9 GHz Logic Boardの画像
製品
$349.99
MacBook Pro 13" Retina (Early 2015) 3.1 GHz Logic Boardの画像
製品
$199.99
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
Adrian さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 9
過去 30 日: 29
今までの合計 4,934
