メインコンテンツにスキップ
250GB HDDとWi-Fiを内蔵したXbox 360のスリム版も出る。修理には複雑なこじ開け作業と特殊な工具が必要です。
307回答 すべてを表示
Why is my console turning off after a few seconds
My Xbox turns itself off after about 2 minutes of being on. I've tried a new power block and have also tried using the Xbox without an extension lead (plugging it straight into a wall socket) I bought a new Xbox 360 S thinking my Xbox had just had it but this has the same problem which doesn't make a lot of sense. Any help or ideas as to why this is happening would be appreciated
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
2 件のコメント
Does it tend to get hot?
さんによる
My xbox 360 is not working after 20 secs i was playing minecraft but my xbox just powered off
さんによる
コメントを追加
2件の回答
最も参考になった回答
I hope you keep our console properly ventilated i had same issue once as i was keeping the console in a tight shut rack, and it used to switch off due to heating up .... try also to check if u have clogged dust near heat sink...hope this solves your problem...
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
My xbox 360 AND xbox one are now both doing this, they both started after i started chsrging my phone off it through usb. If you have had any usb leads for anything id recomend removing them, it may have blown the power boxes or summut. Both of the xboxes when turned on violently vibrate also
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
'Possessed no my stuff doing that too. Too much info I think
さんによる
コメントを追加
回答を追加する
Ferdia Toland さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 9
今までの合計 5,337
