メインコンテンツにスキップ
The Acer Chromebook 11 was released in December 2015. It can be identified by its model name: CB3-131-C3KD.
8回答 すべてを表示
I can't hear any sound. What could be causing this?
I can't get my Chromebook to produce any sound. The volume is turned up to the highest setting, but it still won't work.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 22
4 件のコメント
I’m searching for answers to wonder why?
さんによる
my headphones output socket will not grip properly and sometimes sound cuts out completely
さんによる
I can't hear any sound in my Chromebook. The speakers must be wet. What do I do?
さんによる
@Debbie Winkelman
What is the model number of your laptop?
Why would the speakers be wet? Have you spilled any liquids on the laptop?
If you have DO NOT try to charge or to turn on the laptop.
It needs to be opened and first the battery needs to be disconnected from the motherboard and then the rest of the laptop inspected and cleaned of any liquids and corrosion that is seen using Isopropyl Alcohol 99%+ (available from electronics parts stores).
After that it can be tested to see what any problems are
さんによる
コメントを追加
2件の回答
最も参考になった回答
Try changing the sound output. Click on your account photo, and next to the volume slider, click the Right Arrow. See if you can change where the sound comes from. Please check out our troubleshooting page under the 'sound problems' section for more information.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
In most circumstances that involve Chromebook speaker issues (especially in Chromebooks, as they tend to be weak) the problem with them is that water has gotten into them or they have been tampered with. If this is the case, you should buy a new set of speakers. The other possibility: If you have taken your Chromebook apart before, you may have forgotten to plug your speakers back in or plugged them in the wrong area. It depends on what Chromebook brand and model you are using, however. Then again, it may be something as simple as you have blown them out by playing heavy metal too loud.
このアンサーは役に立ちましたか?
スコア 1
3 件のコメント:
If you have blown them out, you will definitely need a new speaker.
さんによる
I have had this problem before on my Acer Chromebook 11 C720-P
さんによる
To be honest, when I had that problem with my Chromebook, it appeared because several different parts on the Chromebook were simultaneously frying themselves for whatever reason. The Chromebook broke, and I got rid of it, as it would not even turn on...
さんによる
コメントを追加
回答を追加する
adamhendrix さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 9
今までの合計 6,564
