メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Wi-Fi版iPad Mini 2の修理ガイド。2013年10月22日発表、11月12日発売。iPad mini 2はiPad mini Retinaディスプレイモデルとして知られ、iPad Airのすべてのピクセルを7.9インチに小型化しました。
Half of touch screen working
Hi,
My iPad mini 2 (A1489) has only half of its touch screen working.
I opened and verify the connectors: everything seems ok. No missing pins.
I think I see copper through a tiny dent in the cable from the digitizer to the logic board. Exactly where the cable folds.
Should I buy a new digitizer right away or is there any other thing I should check before buying that part?
Also, anything I should look for to avoid buying a bad touch screen? I saw prices range from 10$ to 30$
Can I easily buy a screen without IC connector and just take it from my old screen?
(I am trying to fix this on a budget...)
Thanks!
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
It sounds like the dent in the ribbon is your problem - I'm afraid you need to bite the bullet and order that new digitiser unless your day job is as a brain surgeon! It'll come complete with the ribbon and connector so you can't save anything by transferring a connector from the old one - even if you were a whizz at microsoldering and competent to do so.
As for which to go for, my general rule is avoid the very top of the market - you may be being overcharged for an OEM product which is no better than an aftermarket one, and avoid the bottom - it may be rubbish. And make sure you go for a vendor who has a credible returns policy.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Christian Beland さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 7
今までの合計 163
