メインコンテンツにスキップ
Appleコンピューター以外のキーボード用修理ガイド
242回答 すべてを表示
I spilled water on my keyboard, but it still (Kindof) works
Last night, I spilled water on my keyboard. It had drain holes so I figured it would be fine if I unplugged it and let it dry. I did just that, and when I came back today to play some video games, it seemed mostly dry, but my most important key, the W key, was giving me problems. Is there anything I can still do in an attempt to save my expensive keyboard?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント:
What the make and model number?
さんによる
コメントを追加
1 件の回答
@tkmaida the only thing you can try and do is disassemble your keyboard. Then clean everything with 90%+ isopropyl alcohol and a soft brush. Clean it very good, every nook and cranny (meaning every connector every cable end) then let it sit to dry. After that reassemble and try again. Most likely your keyboard may have shorted out, but you never know until you tried to fix it.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Tristan M. さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 304
