Why did half my screen go dark?
why did half of my sanyo tv screen go dark? right half of screen went dark like a shadow over it. I can still see picture and everything else works.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Rod Skelly a complete loss of drive data for all RGB information to the right side of the screen. This is sometimes caused by the flat cable connecting the T-con board to the LCD panel coming loose as well as a bad T-con board. For anything more about that it will help if you do as @jayeff suggest. We'll need your exact model number and it will help if we can see what you see. Use the link provided by @jayeff
このアンサーは役に立ちましたか?
my left side screen is dark the model number is DP39D14
my tv is the same model. How was the problem resolved?
If this is an older LCD type TV, then it is possible that the backlight on that half has failed. Some of the older TV supplied light from each side. Please post the exact model number of the TV so we can confirm that this is the case or suggest other possibilities. Given the way most T-con boards work, I would not expect this type of symptom from a T-con failure.
Dan
このアンサーは役に立ちましたか?
I have a Sanyo Dp55D44 and my right side of my screen is dim. I checked the ribbons and swapped them around and still same thing. Possible T-Con issue?????
I have the same problem this morning. What could cause half of the screen to be darker?
Hi. The leds are controlled by a separate driver board on this Sanyo model. The board controls the voltage to the leds and is supplied by the power board. Very often its not the backlights themselves but the driver board on this model. Replace with same part and should be good to go. Of course the right way to check is with a led power supply or tester. Check each channel on the leds. There two sets on the left side of driver board bottom and one set on the right side. The first 2 sets should run about 70 volts each while the one on the right should run about 140 volts.
このアンサーは役に立ちましたか?
過去 24時間: 3
過去 7 日: 18
過去 30 日: 58
今までの合計 27,325
3 件のコメント
Hi.
What is the model number of your TV?
Which half are you talking about, top, bottom, left , right?
Try posting some images so that we can see what you can see.
Here's how. iFixitでの質問に画像を追加する方法
jayeff さんによる
Top and sides of screen. Make of TV is philips
jintymccreadie さんによる
The left side of my screen was dark this morning, now the right side is dark and the left is ok.
tthurman2001 さんによる
