3.3 v regulator IC
Please,
Anybody knows the number of 3.3v IC named U3C2?
The image below shows where it's placed.
Thx
Hi, the component you are looking for is called TPS53819ARGT and the below image is the schematic of the component.
Or
If you need the PDF of it is the below link:
http://www.ti.com/lit/ug/slvu719a/slvu71...
and
http://www.ti.com/lit/ds/symlink/tps5381...
Hope that helps!
このアンサーは役に立ちましたか?
@missaircraft I'm also looking for an IC on the release edition of the xbox one. The board location is E3C4. The part is located near the CD drive. I've scoured the internet for the part number and any other markings I could find on it but I've always come up empty handed.
actually U3C2 is a TPS54218 (step down converter)
TPS53819 is used in position U5F3 (buck controller)
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 6
過去 30 日: 28
今までの合計 2,308
I'm looking for the same part number. Did you happen to find it?
IanBtheInventor さんによる
