メインコンテンツにスキップ
Released in November 2013, this model of the HP 2000 series is the perfect device for those on a budget, but don't want to sacrifice performance.
35回答 すべてを表示
pink stripes on dark background and green stripes on white background
i was playing a game when suddenly the screen turned pink. i got worried and closed down the game...and while doing so.. the screen went black as the application shut off....then there was pink color coming from all sides of the screen and stripes form and the screen from black turned pink..and on white background it shows green stripes
It has Intel(R) Pentium(R) CPU B960@2.20GHz processor
System type- is 64bit operating system x64 based processor
please help....
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
Hi!
Your problem could have a number of causes and we will need to work towards excluding the unlikely ones. First, update your post with the specs of your laptop.
Now. The problem could either be the GPU that went bad because of overheating or the display cable, that could also have gone bad due to overheating.
To see which components is not working as expected, connect the laptop to an external display. If you still see the stripes on the external monitor, then it's the GPU that needs to be replaced. If not, it might be the display cable.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
さんによる
If it were to be overheated...what do I do?
さんによる
コメントを追加
回答を追加する
Kizong Lama さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 3
今までの合計 84
