メインコンテンツにスキップ
2015年3月のアップデートではアップルの13インチMacBook Airは第5世代Intel Core i5またはi7プロセッサーを特徴としており、これによりわずかな性能とバッテリーライフの向上がされました。
PPDCIN_G3H at lower voltage
Hi Everyone
I have a board 820-00165-A
The PPDCIN_G3H should be at 18.5 V , but it is at 14.90
I see that PPDCIN_G3H comes from J700, which is the conector to the I/O Board.
What would be the next step on this issue?
Best
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
Do you remember how you solved this?
I have the same board with the same issue PPDCIN_G3H is at 14.4V and the laptop won't turn on.
The fan is spinning at low rpm and it looks like the SMC reset is happening (the magsafe LED is turning back green and then orange)
The history of the laptop is that it was working, I left it for a few months and now, it's in this state.
Thank you
さんによる
コメントを追加
1 件の回答
最も参考になった回答
First of all, Is it powering on? If PPBUS_G3H is at 8.56 I wouldn't worry about it and I'd look elsewhere. Try a new DC in board and a KNOWN GOOD charger and it should be set. If it is still at 14.65 we can go from there but I don't think this is an issue.
このアンサーは役に立ちましたか?
スコア 2
14 件のコメント:
PPBUS_G3H is in 8.58 so I would say it is within the range.
And the charger is proven to work Ok.
さんによる
PPBUS is fine. 8.58 is perfect. Does the system power on?
さんによる
No, and not even the fan
BTW I forgot to add that I have not tried switching the DC board.
I'm from a place where I have to wait at least a week to get the replacements. Should I go ahead an order it?
さんによる
DC IN board is fine if it has PPBUS. U1900 area? PPvRtc_g3h present? PM_SLP_S4 present?
さんによる
PPVRTC_G3H is at 3.42 schematics says it should be at 3. I'm not sure if that is within the range.
PM_SLP_S4 I measure no voltage if that's what present means
さんによる
9件以上のコメントを表示
コメントを追加
回答を追加する
Ernesto さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 10
今までの合計 1,623
