メインコンテンツにスキップ
Repair guides and support for the laptop/tablet hybrid in the Toshiba Satellite Radius series released in 2014.
48回答 すべてを表示
Why is my sattelite asking for a password?
After an update my Toshiba p55w restarted and opened on a page with large white square with a key board and a space that said 'password'. Now I can't get into my PC at all. "F" keys don't work, I can't get into safe mode. In fact I can't do anything. I tried every password I ever used and after 3 tries my PC shuts off. So now it is just a brick.
Let me be clear : I can't do anything. No access to anything but the screen with the white square with keyboard and password. Nothing else, nada, zip, zero, zilch. Any help would be appreciated.
Thanks
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
This sounds like a UEFI password. After the 3rd attempt does it give a code? This is a recovery code and you can use it to get an unlock password from a couple of websites that Google (for some reason) doesn't index. There's a link to them in the External Links section at the bottom of https://wiki.restarters.net/UEFI_and_GPT
If you're in legacy mode (it looks like old fashioned BIOS) then it may be possible to reset the password by shorting a couple of solder pads on the motherboard. On a set of Toshibas I unlocked last year they were visible under a bottom cover plate next to the RAM sockets, and it helped greatly to temporarily solder onto them a push button on the end of a long flying lead. Google may help you find them, if not try yandex.ru, which seems to have less scruples than Google.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Thanks for your answer, however the shorting of the contact points doesn't work on This model Toshiba laptop. There is no message that comes up at all, ever.
After 3 password attempts it just shuts down and when I restart it goes back to
the big square white box with keyboard and password space.
Thanks again
さんによる
コメントを追加
回答を追加する
windell さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 7
今までの合計 954
