メインコンテンツにスキップ
250GB HDDとWi-Fiを内蔵したXbox 360のスリム版も出る。修理には複雑なこじ開け作業と特殊な工具が必要です。
307回答 すべてを表示
RF Board Lights will not come on
I recently switched out the LED's I made sure to apply a decent amount of flux as well as making sure all nothing apart from the original LED's were removed when I applied the new LED's and soldered them again 3 out of 4 did not work so I fixed the soldering there and now none of the lights will come on nothing is burned on the board and all original pieces of the board are in place besides the replaced LED's
The RF board does the usual noise when you turn it on, the controller sync's and the eject sensor works it is simply not showing any lights.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
I cleaned the board with some alcohol and once i let it dry i heat treated it and it has seemed to work perfectly.
Although I am still curious what part of the board powers the LED's?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Eric B さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 3
今までの合計 93
